Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 100,000+ Mileage Foci, Post here..
Old 08-07-2012, 08:45 PM   #864
afraziaaaa
afraziaaaa's Avatar
Fan#: 47383
What I Drive: 2005 ZX4 ST
Points 4,258, Level 41
Points: 4,258, Level: 41 Points: 4,258, Level: 41 Points: 4,258, Level: 41
Level Up 54% Completed
FF Reputation: 24 afraziaaaa Great Standing Member
Buy-Sell-Trade Rating: (10)
Originally Posted by NathanielCatch View Post
Thanks for the info. I took off the valve cover today and checked everything and re-seated my gaskets on the valve cover. They were leaking a tiny bit in the spark plug chamber. I am going to get the sea foam and injector cleaner this afternoon and see what happens.
I'll make a new video as soon as it's done.
Also, can you link me to a thread that this should go on? I am very new.
I would say this thread is fine. Do you have a mechanic's stethoscope? If not, you should get one. like $4 at harbor freight.
Sounds normal for the most part. If no check engine light (CEL), then its probably just injectors. One thing to be concerned about if there is a chattering coming from the engine is the tumble flaps in the intake manifold (you will get a CEL with this problem). Myself, along with a couple other 100k foci duratecs are having or have had this problem.
afraziaaaa is offline
