Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lunchbox delete on my 2012 Hatch :)
Old 08-07-2012, 07:49 AM   #9
Benner's Avatar
Fan#: 77653
What I Drive: 2003 Zx3
FF Reputation: 1 Benner Good Standing Member
Originally Posted by darkangelism View Post
Have you cracked the ecu? It is encrypted by default, none of the top tuning companies have cracked it yet, so if you cracked the encryption you could make way more money by releasing the crack for the ECU. If you havn't tried to flash the ECU yet, you might be wasting your time with all of the other things that you are doing.
Originally Posted by craigsfocus View Post
If you are messing with the ECU, trying to crack it. Prepare to have your warranty void. If you have the DCT, that Turbo kit won't happen until you swap out the tranny. The DCT as it sits won't deal with the power for very long, probably very briefly. Not to mention the stock compression ratio is to high for a turbo, so that would need to be lowered by boring out the cylinders. Then you would need to get some good forged pistons, good rods, good crankshaft bearings, make sure everything is balanced, new camshafts with new bearings, all new gaskets, bigger fuel injectors, I would get one of those dual engine oil filter setups (might as well since you already threw down the $$$ for everything else), upgrade the cooling system, custom 2.5-3 in. Exhaust. All of this and you have even gotten to the turbo and stuff.
You are talking serious cash, especially since none of this stuff exists for the Focus yet. Everything hinders on one thing, the tuning, which none of the big companies have cracked yet. Then you still have to wait for someone to do the research and come out with a tune for a turbo kit.
Might as well buy an ST and call it a day.
Only a matter of time before it's cracked and everyone has free reign on it. The f-150 Ecoboost was giving people nightmares on cracking and now it's just like most other vehicles. And the results on that are simply stunning. granted it's already boosted.
Good luck Op.
Benner is offline
