Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Leak from SPI Intake Manifold
Old 08-06-2012, 06:13 PM   #6
tp4pdb
Fan#: 94593
What I Drive: 2000 Blue Wagon
Points 135, Level 2
Points: 135, Level: 2 Points: 135, Level: 2 Points: 135, Level: 2
Level Up 70% Completed
FF Reputation: 1 tp4pdb Good Standing Member
Problem Solved
It turns out that I apparently installed the two intake manifold gaskets in the wrong order. I guess I wasn't paying enough attention when I took the thing apart a couple of months ago. I then removed the intake manifold (which required a lot more work than the Ford workshop manual indicated), installed the new gaskets in the right order, put it all back together, added water and then pressure tested the cooling system. No leaks.
So far so good.
Paul B-West LA
tp4pdb is offline
