Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus Custom Ram Air How-To
Old 08-06-2012, 11:34 AM   #285
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
What I Drive: 2012 SGM Focus SEL sedan DCT
FF Reputation: 3 Some Guy From NY Good Standing Member
Originally Posted by dyn085 View Post
The difference between a wet lay up and bagging it is that when you bag it you apply a constant suction to plastic surrounding the glass/part. This helps to ensure a tight bond and proper penetration of the glass by the resin.
For taking off the bottom, there are some of the push pins and I believe a couple torx bit screws. Should be pretty easy.
If there is enough material, 3 layers is typically prefered. The first layer, one laid 90 to it,.and then one final laid at 45. In this type of component I wouldn't be overly concerned. I did a wet lay up with two layers, one at 45.
Thanks.
This project of mine is going to be delayed a bit...I want to do it after I get my steering rack replaced...and I spoke to the dealer today who said it may take another 3 weeks to come in. Until then I am amassing the parts/tools to do this.
Some Guy From NY is offline
