Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus Custom Ram Air How-To
Old 08-06-2012, 10:40 AM   #284
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 40,238, Level 100
Points: 40,238, Level: 100 Points: 40,238, Level: 100 Points: 40,238, Level: 100
Forum Activity 5%
FF Reputation: 54 dyn085 Excellent Standing Member
Buy-Sell-Trade Rating: (5)
The difference between a wet lay up and bagging it is that when you bag it you apply a constant suction to plastic surrounding the glass/part. This helps to ensure a tight bond and proper penetration of the glass by the resin.
For taking off the bottom, there are some of the push pins and I believe a couple torx bit screws. Should be pretty easy.
If there is enough material, 3 layers is typically prefered. The first layer, one laid 90 to it,.and then one final laid at 45. In this type of component I wouldn't be overly concerned. I did a wet lay up with two layers, one at 45.
FocusFest 2013: Best of Show
Gateway FFW: Show Class Outstanding
September '13 ROTM
2014 FiST-
dyn085 is offline
