Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Turbo SVT with possible blow by?
Old 08-03-2012, 08:30 AM   #10
drostedrummer89
I <3 my SVT
drostedrummer89's Avatar
Fan#: 69059
What I Drive: 2002 Sonic SVT
Points 5,199, Level 46
Points: 5,199, Level: 46 Points: 5,199, Level: 46 Points: 5,199, Level: 46
Level Up 25% Completed
FF Reputation: 8 drostedrummer89 Good Standing Member
Buy-Sell-Trade Rating: (10)
Originally Posted by Roushturboedzx3 View Post
Prob broken ring lands or leaking valves.
Don't leaking valves only cause air to escape through the intake? There's no way it could pressurize the block, right?
valve cover was off. i have read that sometimes a cracked or warped cylinder head or blown gasket can cause air to exit an ajacent cylinder. I need to redo the test and tap the buckets on cyl 3 to see if the valves snap shut. may also pull the cams.
We are really hoping its in the top end, we don't want to get into a full rebuild.
as a side note, we did the same leakdown test under the same circumstances a few months prior, and we had ALOT of air leaking from valvecover. like over 20% on 2 different cylinders. we were surprised that we didn't get anywhere near the same results. we'll do it a third time and check back.
Matt
Droste Drummer. Droste like Frosty.
00" Red ZX3: Volant, ported throttle body, titanium wrapped SVT header, 2.5" exhaust, Magnaflow res/muffler, FR UDP, Mac cam gears, Lowered 2", Koni's.
drostedrummer89 is offline
