Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - When Did you change your timing belt
Old 07-31-2012, 10:33 AM   #108
Fan#: 100311
What I Drive: 2002 CD Silver SVT #253
FF Reputation: 1 jasbsvt Good Standing Member
Changed at 87,000. Belt and pulleys all looked good.
There is an "alignment" flat bar that sets the cams, and there is a screw in "bump stop" alignment tool that sets the crank. You will need both tools - don't attempt this job without them.
FYI - set the cam alignment tool BEFORE sliding the belt off. I was 180 out when I went to set align the cams and had to step away for a moment. Put the belt back on, rotated the moter, aligned and got no codes. Consider myself very lucky in this regard.
jasbsvt is offline
