Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2006 Shift Tower Roll Pin Issue
Old 07-31-2012, 06:29 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,454, Level 100
Points: 32,454, Level: 100 Points: 32,454, Level: 100 Points: 32,454, Level: 100
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
I have a bolt in mine. It's nice to know that a 6mm will work. I expected 5mm since the 1/4" bolt I had nearly fit. You should use a grade 8 bolt, and if you can find one- nylon locking nut. Jam-nutting is fine, but a single nut and red thread lock would be acceptable.
What you're really looking for is called a spring pin. You'll remember that the Autozone rolled pin didn't look the same as what you took out of there. Yours would've been a harder steel thinner steel rolled several times around itself. Autozone's rolled pin would look like a round pin with a gap in it- one piece of metal.
I personally would like to replace the part with the correct spring pin, but a bolt is acceptable if it's a high strength or hardness. SS is the hardest, but something like a 10.9 or grade 8 would be hard enough and maybe not damage the shift tower. Stick with the bolt IMO.
Thanks again for letting me know a 6mm would work. BTW I used a cap screw (allen head) instead of a bolt. That made it easier to work.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
