Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Yet another high idle problem
Old 07-30-2012, 05:50 AM   #11
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,855, Level 100
Points: 32,855, Level: 100 Points: 32,855, Level: 100 Points: 32,855, Level: 100
Forum Activity 38%
PCV valve should be checked every 20k miles or every 3-4 oil changes. You test it by removing it's hose from the port and blowing into it. You should feel a lot of resistance, and ideally not be able to blow into the engine. Then suck lightly and you should be able to draw in some oily smelling air from the engine. That is a proper working PCV.
We've noticed lots of problems with the PCV vacuum line on older Zetecs. The line will crack and leak vacuum, and sometimes the line will collapse under idle. Be sure to double check this line or replace it, or at least replace the rubber elbows. Ford makes an insulated replacement part that is better than the factory part for $20.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
