Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Saleen Focus owners!!
Old 07-28-2012, 11:07 AM   #102
chaz493
chaz493's Avatar
Fan#: 12862
What I Drive: 2013 Performance Blue Focus ST2
Points 1,285, Level 19
Points: 1,285, Level: 19 Points: 1,285, Level: 19 Points: 1,285, Level: 19
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 2 chaz493 Good Standing Member
Originally Posted by netjeeps View Post
Thanx...
Don't mean to hijack the thread in another direction but considering this thread is for Saleen owners. Has anyone spaced the stock rims out to the edge of the flairs? If so, any issues with rubbing when you did it. I love the Saleen but don't like how the tires sit so far inside the flairs.
I didnt space the stock rims, i spaced my new rims i got though. In order to get the wheels to look flush you need a 20 mm spacer on each wheel, i got the H&R kit that comes with extended lugs. There will be rubbing, maybe not on the stock rims as mine are 8 inch wide rims not 7.5 inch.
Maybe by going with 15mm per wheel instead of 20 you can get away from scraping but they wont be flush, but im sure way better than stock. You could also cut away plastic from the inner side of the flares and roll your fenders to create clearance.
chaz493 is offline
