Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Custom RetroFit HIDs
Old 07-26-2012, 02:33 PM   #13
BIMMERKID21
Fan#: 98852
What I Drive: 2012 VW Passat SE TDI Dark Blue
Points 551, Level 11
Points: 551, Level: 11 Points: 551, Level: 11 Points: 551, Level: 11
Level Up 2% Completed
FF Reputation: 1 BIMMERKID21 Good Standing Member
I know about the resistors.. got that... but check this out.. i'm going to delete the turn signals in the grille anyways. because i got a Euro Grill that I'm putting in. by deleting the signals in the grill... that makes my install work for the Euro grill that much easier
Originally Posted by 02fordsvt View Post
First off, sorry the link I provided wasn't of more help to you.
Now for wiring in your headlights. From the picture, it looks like the plugs are already prewired to work for your car. Have you tried simply plugging them into the existing headlight plug on your car and seeing if they work?
To wire in your signals, simply wire them directly to the grill turn signals. You will need the resisters, however, if you use LED bulbs for the turn signals.
Midwest Crew
RIP my ole focus maybe someone can fix u up better than i can.... enough with the suspension issues......
BIMMERKID21 is offline
