Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Question about post-cat O2 sensor
Old 07-22-2012, 10:41 PM   #13
amc49
Fan#: 96610
Points 6,408, Level 52
Points: 6,408, Level: 52 Points: 6,408, Level: 52 Points: 6,408, Level: 52
Level Up 29% Completed
Forum Activity 100%
A plugged cat will run worse at higher rpm if it is bad enough to affect idle.
Common to check for vacuum leaks by plugging all fittings you can temporarily and then testing idle quality. Once the plugins are isolated as good then you go to gaskets and/or possible cracking somewhere to leak unmetered air.
amc49 is offline
