Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Question about post-cat O2 sensor
Old 07-22-2012, 08:05 PM   #12
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,439, Level 29
Points: 2,439, Level: 29 Points: 2,439, Level: 29 Points: 2,439, Level: 29
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 11%
Activity: 11% Activity: 11% Activity: 11%
Buy-Sell-Trade Rating: (3)
Originally Posted by Joboo View Post
Is that the one that goes into the sensor on the left side of the fuel rail?
Yes.
Everything else looks like reinforced lines with special connectors.
While the vacuum tubing is some kind of special hard plastic - crimps fairly easily btw - the connectors clustered at the top of the manifold are simple push on rubber fittings (except for the big EVAP fitting). You can pull them off one at a time and inspect. Try blocking the port temporarily and see if the idle improves to try isolate any offending line.
Did you replace the PCV elbow and valve (front of the engine) when you repaired the collapsed rear hose?
BC_ZX3 is offline
