Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The best Rpm right off the start...
Old 07-22-2012, 05:15 PM   #12
SMITHBOY76908
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
Points 14,742, Level 78
Points: 14,742, Level: 78 Points: 14,742, Level: 78 Points: 14,742, Level: 78
Level Up 73% Completed
Forum Activity 4%
FF Reputation: 19 SMITHBOY76908 Great Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by sporadic View Post
The answer: give it as much RPM as you can without spinning the tires or breaking an axle.
If you spin, get stickier tires. Increase RPM until axle breaks.
This.
I launch from 5k with about 8psi built up on the 2-step. If the track is decently prepped, it hooks right up (slicks). My clutch slipped last time out though. Even dead hooking dropping the clutch from 5k, I haven't broken an axle from launching. I've broken 2 axles due to potholes though.
There's way too many variables to say what RPM to launch from, even with a stock car. Differences in track prep, track surface material (asphalt, concrete, etc...), and time of day can all make a difference. You just have to get out there and find where it likes it best.
Originally Posted by Texas Ghost View Post
lol i guess i should have mentioned to burn out i just ASSumed he knew that
Don't do a burnout on street tires, you're wasting your time. Street tires actually lose traction when heated due to the rubber used in radial tires. If you're working with slick compound, then yes heat them up. Slicks become stickier when hot, the opposite of a street tire. Also, going through the water with street tires is just going to get water trapped inside the grooves that will make you spin off the line even worse.
07 ZX3 - 300whp and I'm bored with it!
66 Mustang & 85 Bronco - resto projects!
06 MX5 - ...
SMITHBOY76908 is offline
