Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Key Fob Programming How-To
Old 07-22-2012, 12:46 AM   #9
SD_ZTW
SD_ZTW's Avatar
Fan#: 91209
What I Drive: 2003 White ZTW, D23 PZEV, ATX
FF Reputation: 2 SD_ZTW Good Standing Member
The procedure is a little different for 2000-2006 vs. 2007-2011.
Sit in car, doors closed:
2000-2006
1. Turn the ignition from "Off" to "Run" four times in six seconds. Key stops in "Run" position on fourth cycle.
2. Turn the ignition to "Off." The car will chime to confirm that you've done everything correctly so far. Key is still in ignition
3. Press any key on the first remote you're programming. Perform this within 20 seconds of Step 2. The car will chime to confirm programming.
4. Repeat Step 3 with each additional remote*, all within the 20 seconds. Remove key from ignition.
*The remotes should be inside the vehicle during the procedure (eg. all on front seat.)
2007-2011
1. Turn the ignition from "Off" to "Run" eight times in ten seconds. Key stays in "Run" position on eighth cycle. The locks will cycle to confirm that you've entered programming mode.
2. Press any key on the first remote you're programming. Perform this within 20 seconds of Step 1. The door locks will cycle to confirm programming.
3. Repeat Step 2 with each additional remote, within 20 seconds of the prior programming. The locks will cycle after each successful programming.
4. Turn the key to the "Off" position to exit the programming mode. Remove key from ignition.
SD_ZTW is offline
