Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Key Fob Programming How-To
Old 07-21-2012, 11:35 PM   #6
elsolo
elsolo's Avatar
Fan#: 96835
What I Drive: 2007 white ZX3
Points 3,196, Level 34
Points: 3,196, Level: 34 Points: 3,196, Level: 34 Points: 3,196, Level: 34
Level Up 98% Completed
FF Reputation: 18 elsolo Great Standing Member
Originally Posted by valflyinf View Post
I just spent 10 minutes at my car to do this procedure. I was under the impression that you could do this to two fobs for one car, am I right? I was only successful with programming either one or the other but not both. I even tried to press a button on both fobs at the same time but still, only one ever gets programmed.
Any insight?
I forgot to mention the obvious, I ordered 2 fobs, which I received in the mail today.
I was going to keep one at home in case I lock myself out of the car, and one main one hooked to the ignition key ring, for everyday use.
I had the same problem, similar at least.
I order two off ebay, one took the programming every time, the other would not.
It didn't matter which I tried to program first, the same one wouldn't ever work. I assume I got a dud fob, but now I am almost second guessing that.
From what I read, you should be able to do four fobs at one time.
elsolo is offline
