Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rattling heat shield fix.
Old 07-19-2012, 02:15 PM   #13
Ralliman
Ralliman's Avatar
Fan#: 99721
What I Drive: 2003 Infra Red SVT ZX5
Points 775, Level 14
Points: 775, Level: 14 Points: 775, Level: 14 Points: 775, Level: 14
Level Up 75% Completed
FF Reputation: 2 Ralliman Good Standing Member
Originally Posted by JBotone View Post
I was able to get all of them but the one on the far left. The aluminum bracket got in the way, I cussed and yelled for about an hour before I gave up. With the other 3 on the underside it holds nicely. The one on the far right should move enough to get it in position, you have to take your time and be careful but it's not too difficult. I slid the bolt from the back side, and it's close enough to sit it on the manifold. Lift the shield and keep it from knocking the washer off as you move it back.
I've got the washers (reusing the original bolts since Lowe's didn't have 10mm/5mm bolts), so I'll give it another try soon. I did find the source of my rattle-the shield's rusted away around the bottom bolts. I got the washers in place on both sides, locked down the top bolts with washers on the outside, and the rattle is completely gone!
Ralliman is offline
