Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rotor Upgrade Questions
Old 07-18-2012, 10:50 AM   #11
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
Points 4,394, Level 42
Points: 4,394, Level: 42 Points: 4,394, Level: 42 Points: 4,394, Level: 42
Level Up 22% Completed
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by Geezer View Post
I'd simply tell them you want SVT rotors for the rear (or whatever model you got them from) and front rotors for the particular year and model Focus you have. It need not be anymore difficult than that. If they give you a dumb look simply tell them you upgraded the rear from drums to discs using available stock parts from another model Focus.
Thanks Geezer!
I am going to stop at NAPA after work and I will see what they come up with. I will let you know $$ when I get them.
Also I am not going to be replacing the front rotors, just the rear.
EDIT: If I get the standard rear rotors for an SVT (which is what the breaks are from) will they be bigger than my front rotors and if so will this cause any problems?
If you can't wear it out, burn it off
DarderSauce is offline
