Old 07-15-2012, 04:09 AM   #1952
LMMT_
Fan#: 97850
What I Drive: 12 Sterling SEL
Points 7, Level 1
Points: 7, Level: 1 Points: 7, Level: 1 Points: 7, Level: 1
Level Up 13% Completed
Level up: 13% Level up: 13% Level up: 13%
FF Reputation: 1 LMMT_ Good Standing Member
Originally Posted by TiPilot View Post
Ran into a new one last night...
We were at a drive-in theater (engine off, radio on) and this popped up. I had to restart the car to get it to go away. There was no sign of it being a battery/discharge problem, as the MFT system remained on, but maybe there's some connection there?
Have any of you seen this before?
This thread is the only mention I see on here.
I've had this issue, since I bought the car. It's been looked at several times, by the dealer I purchased the car from. I consulted (by phone) just about every Ford dealer service department in the Houston region, no help. I did the procedure, to disable vehicle transport mode, and the car responded with proper prompt, letting me know the procedure was a success, but it would still go into vehicle transport mode, within a few minutes of engine off, with the key in accessory position. I tested my battery several times, but it always tested good. I discovered, that if I bumped the battery, while it was being load tested, it would sometimes fail. I took the car to a Master Service Advisor, that seemed knowledgeable, at another dealership, that I'd talked to previously, and explained everything. Eventually they reproduced the problem, and replaced the battery. I haven't had any problems since.
Sent from my EVO using FF Mobile
LMMT_ is offline
