Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - fswerks stage 2 possibly have a dying cylinder
Old 07-14-2012, 12:27 AM   #14
Barrow88
Barrow88's Avatar
Fan#: 91009
What I Drive: 10' Black SES, 02' Boosted ZX3
Points 964, Level 16
Points: 964, Level: 16 Points: 964, Level: 16 Points: 964, Level: 16
Level Up 64% Completed
FF Reputation: 4 Barrow88 Good Standing Member
You can get full rebuild kits from here: https://www.gp-werks.com/categories/...-Rebuild-Kits/ or you could just piece together pistons and rods then get your gaskets elsewhere.
Here are the 2 rebuild kits:
2.0L Duratec Rebuild Kit: $1,515.00
2.0L CP Pistons with Rings 87.5mm or 88mm (8.5 or 9.0 compression ratio)
2.0L GPWerks/K1 Connecting Rods w/bolts
2.0L Forged Crankshaft
Mahle/Clevite Rod Bearings
Mahle/Clevite Thrust Bearing
Mahle/Clevite Main Bearings
OE Rear Main Seal (with plastic insert for easy installation)
OE Head Gasket
OE Head and Main Studs
2 Diamond Washers
New Main Crank Bolt
Or
2.0L Duratec Rebuild Kit: $1,325.00 (excluding tax)
2.0L Supertech Pistons with Rings 87.5mm or 88mm (any compression ratio)
OE Head Gasket
2 Diamond Washers
New Main Crank Bolt
'10 SES
Build Thread:
ZX3
Build Thread: Already Built... For Now
Barrow88 is offline
