Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - sporadic's Turbo Duratec build #2
Old 07-11-2012, 09:57 AM   #38
sutyak
sutyak's Avatar
Fan#: 12724
What I Drive: Turbo 04 DSG Mach 1
Points 15,350, Level 79
Points: 15,350, Level: 79 Points: 15,350, Level: 79 Points: 15,350, Level: 79
Level Up 50% Completed
FF Reputation: 62 sutyak Excellent Standing Member
Buy-Sell-Trade Rating: (16)
This is the boost controller I went with:
I bought it open-box from ebay, so I wanted to make certain it wasn't busted up so I took it apart. This is what is inside. This one is indeed new.
For those wondering how this works, it is a bleed-off type boost controller. That means it will bleed off a preset amount of air going to the wastegate.
This controller has two stages of bleed-off, controlled by a switch. The only electronic part in this system is the solenoid that opens the path to the second bleed dial. It appears it would work fine as a single-stage without any 12v signal.
The dials are reverse threaded. Turning counter-clockwise closes the bleeder valves. Turning clockwise opens the bleeder valves to increase boost.
I have not installed this yet. I ordered a vacuum block and it won't be here until later this week. I'm going to clean up some vac/boost lines so my boost gauge, boost controller and bov all get the signal from the same vac block.
I'm going backpacking/flyfishing for a few days next week, so don't expect any updates until after.
mark
'04 Mach 1. Built. Turbo. 667whp/631wtq
'06 Focus. Built. Turbo. WMI. (sold)
'03 Mach 1 : 12.61 @ 106.59 (sold)
sutyak is offline
