Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Changed almost everything but car still over heats!
Old 07-10-2012, 05:48 AM   #11
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,615, Level 100
Points: 32,615, Level: 100 Points: 32,615, Level: 100 Points: 32,615, Level: 100
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
Do the electronic odometer test to show the temp (in C) that the sensor is reporting. It might be that you have a bad sensor. We've had a few people with elusive overheating problems that aren't actually overheating. Throwing parts at the car can be expensive, so seek to diagnose first.
Do you have access to an infrared thermometer? That can be helpful in verifying that the temp being reported by the sensor is close to the temp of the coolant in the engine. I measure at the upper radiator hose.
When watching the temp on the electronic odometer test mode, you're looking for outrageous jumps in temp, like to 200C, which is ridiculous and would melt rubber hoses instantly.
On second thought, since you're not going full overheat- needle pegged right, then you probably don't have a problem with the temp sensor. Does the car overheat at highway speeds?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
