Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Changed almost everything but car still over heats!
Old 07-10-2012, 05:33 AM   #9
KrisQ
Fan#: 101129
What I Drive: 2001 Blue SE
FF Reputation: 1 KrisQ Good Standing Member
Thank you all for the suggestions! Special thanks to sailor.
I though about the fact that the heat shield is missing but I could not believe that the engine bay temp can be that much hotter without the heat shield so I removed the exhaust manifold and found a small crack. The crack is located on the first pipe on a weld seam.
I'll see tomorrow if I can have it welded or if I have to find a replacement.
I'll update after this part is fixed.
Thanks to you all again.
KrisQ is offline
