Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - My Oil Change Interval Debate Rant
Old 07-08-2012, 02:29 PM   #228
UnleashedBeast
UnleashedBeast's Avatar
Fan#: 100738
What I Drive: 2012 Focus Titanium
FF Reputation: 3 UnleashedBeast Good Standing Member
Originally Posted by mikefocus View Post
How long did it take to install? Start to finish. Also on a scale from 1-10 what was the difficulty ?
1last thing did you run in to any problems worth mentioning? Thanks.
Install time is probably 2-4 hours depending on breaks.
I'd rank install difficulty around a 7. It's not for the novice, but doesn't require a pro. You want the proper tools to do it.
No problems were encountered at all. The hose and fittings are so high end, you'll be amazed. I check for leaks and oil level daily. The level remains consistent and filters so clear, the oil looks like water on the dipstick. It puts a smile on my face every time I check the oil level.
7 quarts of oil fills up the sump, both filters, and lines.
Parts list for the 2012 Focus.....
BMK23 - install instructions
BK295
EABP90
EaO34
Optional: Instead of a dual remote bypass filtration kit, you can use the single filter bypass setup. It's easier to install and requires less space.
BMK21
The inlet will tap into the oil pressure sensor mounting location, and the return line can be tapped into the oil fill cap. The single remote bypass kits allows the EaO34 full flow filter to remain in the factory location.
2014 Mustang GT custom ordered to replace the GT500: Sterling Gray, NAV, Recaros, Brembos, Glass Roof, back up camera, 6 speed auto, loaded
2012 Focus Titanium - 18" wheels with handling package
2009 GT500 Shelby (700 rwhp) - sold
UnleashedBeast is offline
