Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - My turn! Build Thread time!
Old 07-06-2012, 08:54 PM   #51
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 8,297, Level 61
Points: 8,297, Level: 61 Points: 8,297, Level: 61 Points: 8,297, Level: 61
Level Up 49% Completed
FF Reputation: 9 ViperThreat Good Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by PumkinSvt View Post
its not that bad the ep3 is worse! lol
Have you replaced a clutch yet? There is a bolt that goes to the starter motor from the transmission side.. It also goes to a ground and a bracket.. That bitch... 2 ing hours to get that thing on.. cuz its in a place where you cant really reach it.
Update:
The pretty stuff is on and bolted tight. It wiggles a bit though, so i want to get some sort of bracket to really make that thing solid tight.
To do list is still scary long though:
Turbo Oil Line In
- remove/cut ignition coil bracket
- Get Fitting & plumbers tape
Dipstick
- Stock doesn't fit?
Injectors
-install em
Exhaust
- Get old bolts out
- Replace bolts & Nuts
- Get cat and flexpipe back up and bolted on
- replacement gaskets?
Boost Controller
- Install boost controller unit (where to install?)
- Run cables to cabin
- hook up electronic controller in cabin
Boost Gauge
-run cable to cabin
-hook up power to gauge for lighting
Wideband Gauge
-Run cables to cabin
-hook up power to gauge harness
Catch Can
- find a place where it fits.
Final Parts
-Install axles and hubs
-Install suspension
-Wheels
-Firewire cable for datalog to SCT
-Battery
-Gauge Pod
-Bumper/headlights/grille
Then its tune time!
Moderator For:
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
