Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - My Oil Change Interval Debate Rant
Old 07-06-2012, 10:48 AM   #205
BiggerBoat
BiggerBoat's Avatar
Fan#: 85913
What I Drive: 2012 Red Candy Titanium Hatch
Points 496, Level 9
Points: 496, Level: 9 Points: 496, Level: 9 Points: 496, Level: 9
Level Up 92% Completed
FF Reputation: 3 BiggerBoat Good Standing Member
Originally Posted by UnleashedBeast View Post
You are correct about higher NOACK causing more deposits in a direct injected engine. That's why I choose to use the lowest NOACK percentage available in Amsoil ALM 5W-20 Signature Series. I will also be installing an oil separator to get what little does evaporate in the crankcase and sucked into the PCV system. Since Signature Series has half the NOACK %, it will also have 50% less chance for potential deposits.
For the record, Motorcraft 5W-20 synthetic blend has a very high NOACK in the 13-15% range.
Interesting. I tried to look up this value for Mobil 1 Extended Performance but their spec sheet did not seem to list it. Have you ever seen a Mobile 1 spec that include this value?
http://www.mobil.com/USA-English/Lub...rformance.aspx
BiggerBoat is offline
