Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Warning about K&N Intake
Old 07-02-2012, 03:45 PM   #76
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,831, Level 25
Points: 1,831, Level: 25 Points: 1,831, Level: 25 Points: 1,831, Level: 25
Level Up 31% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by nhemti View Post
Mine looks just like yours TBone so it certainly isn't isolated. I haven't noticed an issue yet because of it but I am keeping an eye on the filter and checking that it is still seated tightly very regularly.
My concern from that issue is not that the filter will fall off. My concern is that, since the MAF isn't properly "suspended" in the hole by the rubber mounts, the vibrations from the engine/throttle body will not be properly isolated from the MAF. Also, engine movement could cause a binding situation between the MAF housing and the heat shield. This could cause damage (cracking) to the housing itself in the long run.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
