Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Warning about K&N Intake
Old 07-02-2012, 08:36 AM   #48
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,831, Level 25
Points: 1,831, Level: 25 Points: 1,831, Level: 25 Points: 1,831, Level: 25
Level Up 31% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by underbird10 View Post
Instead of tightening the clamp until you crush the housing, which will ultimately leave the filter loose and allow it to fall off, what we need here is more friction between the filter shell and the MAF housing itself, without having to overtighten the clamp. My thoughts were to get some of that industrial velcro and with a little Super Glue to help hold it, wrap a strip of the hook side around the MAF housing, or the inside of the mouth of the filter. This will create a nice amount of friction between the two pieces that would allow you to run the clamp down snugly, but not overtighten it. If that didn't work, I was considering using a strip of 200 grit sandpaper instead. Same concept, just glue it to the inside of the mouth of the filter, or around the edge of the MAF housing to increase friction.
That could possibly work. Thanks for the suggestion.
In my experience, the overtightening can be avoided, and yet still get a good seal and retention with the current setup. Just tighten the filter until friction will not allow you to rotate it by hand, then give the clamp screw another 1/4-1/2 turn. It will seem by the force required to turn the clamp screw that it's not tight enough (and thus why we tend to overtighten I think), but it has worked very well for me.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
