Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - TSB 12B37 - New?
Old 06-27-2012, 09:48 AM   #438
fatfocus
fatfocus's Avatar
Fan#: 90985
What I Drive: 2012 Frosted Glass SEL Sedan
FF Reputation: 1 fatfocus Good Standing Member
Originally Posted by dyn085 View Post
If your car has hesitation with throttle application, your best fix well be a better air filter and/or better gas. I don't think that the TSB did anything that could cause that as it (to my knowledge) only affected how the clutches shift and the ABS for holding the car on a grade after you switch from brake to accelerator.
I know that hesitation is frustrating, a put 87 octane in a week or so ago. I felt like there was something wrong with my car. After swapping back to 93, all is good.
Don't underestimate the effect that heat has on our engines. While (imho) the engines perform really well, they seem hyper-sensitive to small environmental changes. This is obviously not a fact, just my observation in comparison to my mechanical background.
It's definately related to the transmission. I'm using 93 shell-V also and have a K&N filter. After having the TSB done in May, the car was great, after the recall, it started out okay, with some shutter, st times, in 1st. I was hoping it would go away......it hasn't.
Now: 2012 SEL Sedan, with Selectshift Transmission, 17" Polished Aluminum Rims, K&N Air Filter
Previously: 2000 White ZTS, 15" Painted Aluminium Rims
member
fatfocus is offline
