Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - E Prepared Battleship Build
Old 06-26-2012, 07:54 PM   #1
ThatOneFocusGuy
1.0 Powa
ThatOneFocusGuy's Avatar
Fan#: 59087
What I Drive: 15 MM Fiesta 1.0, 00 Kona Edition
Points 11,494, Level 70
Points: 11,494, Level: 70 Points: 11,494, Level: 70 Points: 11,494, Level: 70
Level Up 61% Completed
FF Reputation: 7 ThatOneFocusGuy Good Standing Member
Buy-Sell-Trade Rating: (29)
I have owned the Battleship for almost a year now and it is now time to start some projects. Here is the car.
2002 ZX3
Engine:
4-1 Race header/Flex Pipe 2.5''
Trubendz 3'' Exhaust Magnaflow Muffler w/ 14'' Magnaflow Resonator
AEM Cold Air Intake
Focus Central Water and Crank Pulleys
VF Engineering Driver Mount
VF Engineering Passenger Mount
Transmission:
Torsen T2 Limited Slip Differential
Ford Racing 4:06 Gears
Suspension:
Koni Yellow Shocks/Struts
H&R Race Springs
SVT Brake Swap Front and Rear
Hawk HP+ Front Pads
Russell Stainless Steel Brake Lines
SVT Rear Sway Bar
LCR Camber Plates
Eibach Camber Bolts
Wheels/Tires
Rota Slipstreams 15x7.5''
4 Hankook Ventus Z412 C71 225/45/15
2 Hoosier A6 225/45/15
Interior:
Gutted
4 Point Roll Cage
Sparco Evo 2 Plus Seat
G Force 5 Point Belts
RS Shift Knob
Exterior:
SVT Front Bumper
SVT Mach Hids
Mach 1 Fuel Door
Need To Install:
Ford Racing Head
Crower Valvesprings and Retainers
Comp Cams stage 3s
Esslinger Cam Gears
Focus Central Throttle Body
Top Speed Intake Manifold
CFM 3'' MAF Housing
SVT MAF
SVT Injectors
SVT Spoiler
CFM Thermostat Housing
CFM Dogbone with Race Bushings
180 Degree Thermostat
Alternator
Eibach 25mm Rear Sway Bar
AEM Wideband
Waiting On:
Team Dynamics Pro Race 1.2 15x8 ET35 Gold
Need To Buy:
Ford Racing Valves
Head Gasket Set
Battery
AEM Oil Pressure
AEM Oil Temperature
225/45/15 Street Tires Rivals or RS-3s
New Vinyl Numbers or Magnets
Updates should be up soon.
ST Nation Cincinnati Area
2015 Fiesta 1.0
Cincy SCCA 43 STS
ThatOneFocusGuy is offline
