Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Suspension fix - no more front end clunk
Old 06-25-2012, 05:39 PM   #34
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 5,996, Level 50
Points: 5,996, Level: 50 Points: 5,996, Level: 50 Points: 5,996, Level: 50
Level Up 23% Completed
FF Reputation: 1 raptor1956 Good Standing Member
Originally Posted by slowmazda3 View Post
Brian,
I am aware of this; however, camber is relatively fixed with the McStrut design the focus uses. Short of lengthening the control arm there is no possibility of increasing camber on the Mk3 platform (plates will not work as the strut tophat is boxed in.
I also am speaking relative to the OE dampers which leads me to believe I dialed in a bit too much rebound stiffness and in turn reduced weight transfer. The passive rear steer/toe gain on the control blade suspension setup relies on weight transfer for rotation.
The focus is surprisingly agile and gains little camber with steering input when compared to other McStrut designs (A La BMW).
Thank you for your input.
Have you lowered the FF? If not, lowering will tend to make the camber more negative.
Brian
raptor1956 is offline
