Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Louisiana
Thread: Louisiana
Old 06-23-2012, 03:15 PM   #237
milkweed
Fan#: 40906
What I Drive: 2007 ford focus zx3 red
Points 799, Level 14
Points: 799, Level: 14 Points: 799, Level: 14 Points: 799, Level: 14
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 1 milkweed Good Standing Member
on your dash? or on your speedo? if on your speedo gauges aren't illuminating you may need to replace the bulbs, or you can get a speedo face cover from speedhut.com or zxtuner.com if the bulbs aren't the issue then you could try searching the classifieds on here, to see if someone is selling a speedo although you would have to match the year and you're odometer will not show the true mileage, plus i'm sure since you have a svt you would want to replace it with another svt speedo. but i would go the easiest route first and just take the speedo cluster apart and check the bulbs first. there's a stickie in the how to's to show you have to dissembler the speedo and it's not that hard to do it .
milkweed is offline
