Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 Ford Focus SE Zetec DOHC Idle Rough, Erratic, & Stumbles
Old 06-23-2012, 08:17 AM   #9
oshoguno
Fan#: 45853
What I Drive: 2012 Focus SE Hatchback
Points 857, Level 15
Points: 857, Level: 15 Points: 857, Level: 15 Points: 857, Level: 15
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 1 oshoguno Good Standing Member
If it is not a vacuum leak or the collapsed hose/elbow that is so common on these engines then I would do a Seafoam treatment (including the sucking up of the fluid through a vacuum line). I suffered low power, low idle and horrible mileage and did all of the usual stuff to fix, to no avail. I don't normally go for the "treatments" but I thought "what the hell" and gave it a try. What a difference! My engine has as much power now with the a/c on as I had before with the a/c off. I went from 450km per tank to 510km per tank on the next two fills. Engine runs smoother, idle is steadier and I am a lot happier.
oshoguno is offline
