Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Remote Start and "Open Door Shut Off"
Old 06-21-2012, 07:54 PM   #82
Kgodreau
Fan#: 100248
What I Drive: 2012 focus ti
FF Reputation: 1 Kgodreau Good Standing Member
Originally Posted by Yamazama View Post
The dealer installed remote start kit for the 2012 Focus is unique. This information probably won't transfer over exactly to other cars but the menu access & navigation will be the same. I have only tested this on a fully loaded 2012 titanium, auto, with push-button start & MyKey. I have a uni-directional remote start, not the bi-directional.
This is combination of Option Bank settings (LED on or off) required to achieve:
-No honk at start
-No shut off when handle is touched or if the door or liftgate are opened.
-15 min run time
-2.5 sec hold on button to start
Menu Description:
Option Bank 1 - 4 chirps
Option 1: Tach Learn (N/A)= OFF
Option 2: Door Ajar Polarity(On=pos; Off=Neg) = OFF
Option 3: Key in sense Polarity (On=pos; Off=Neg) = ON
Option 4: Extended Horn Output (On=3x horn output; Off=Normal horn ouput) = OFF
Option Bank 2 - 5 chirps
Option 1: Blind Crank of Tach Mode (On=blind crank; Off=Tach Mode) = OFF
Option 2: Crank Time (On=1sec; Off=8sec) = ON
Option 3: Run Time (On=15min; Off=10min) = ON
Option 4: Start Activation (On=hold 2.5 seconds; Off=double press button) = ON
Option 5: Diesel Timer (On=30sec crank delay; Off=No Delay)= OFF
Option 6: Hon on Start (On=honk confirmation: Off=No honk) = OFF
The key to the no horn/no shutoff combo is changing Bank 2 Option 1 to OFF in combination with Bank 1 Option 4 to OFF. If you leave Bank 1 Option 4 ON it will chirp 4 times at start up but not shut off on door opening. You can toggle the other options to suit your prefs. Those 4 chirps are just the system telling you that your tach needs to be programmed because you've changed Bank 2 Option 1 to Tach Mode (which it isn't) so it expects a signal between the remote start module and the engine. There is no connection in this case, hence the error chirps. I am not sure at all why this works. I'm uncertain as to why Tach Mode seems to cancel the auto shut off. If you make a mistake you can always reset the settings to default by holding the transmitter button for 3-4 seconds while in menu mode at any time. Next, change Bank 2 Option 1 to ON, and you should be at your factory installed settings.
Please post your experiences.
Yamazama
I had this same problem with a Bi Directional starter, remote push start 2012 titanium.
I brought in a copy of this thread to my ford mechanic and he was able to set up my focus as follows : no horn at start, locks door when start button is pushed and when i get up to the car my key fob unlocks the door and the car does not shut down. The only issue now is that I have lost bi directional functionality, it does not beep on my remote when I start the car and I can no longer shut it off with the car starter.
This is a non issue for me because I do not require these functions.
I am very happy I no longer need to start my car twice once winter hits...
Thank you very much Yamazama!!
Kgodreau is offline
