Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 Ford Focus SE Zetec DOHC Idle Rough, Erratic, & Stumbles
Old 06-21-2012, 02:56 PM   #7
mpcv2000's Avatar
Fan#: 23629
What I Drive: 01 SE + 1989 RX7
FF Reputation: 19 mpcv2000 Great Standing Member
I've found the problem this morning.
There is a hose behind the intake ( Vacuum ) that when engine is warm ( hose is warm too ) the hose colaps on itself and the engine start running very rough and then die.
When I reset the ECU it gives time for the hose to cool down and retake it's shape.
When the engine does it , just grab the hose behind the intake and squeez it the other way it is collapsed and the motor will run like it should.
I have put a worm gear clamp over it so it doesn't collaps until I get the hose from Ford.
I had this issue with a 00 ZX3 a while back and I kind of forgot about this "infamous" vacuum hose collapsing on itself .
Martin !
mpcv2000 is offline
