Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Brake and Suspension Interchange Guide 00-06
Old 06-18-2012, 08:49 PM   #82
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,814, Level 95
Points: 24,814, Level: 95 Points: 24,814, Level: 95 Points: 24,814, Level: 95
Level Up 47% Completed
Level up: 47% Level up: 47% Level up: 47%
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
Brake upgrades
Originally Posted by Stui420 View Post
I have an 01 ZX3 stock brake setup. i am wanting to go to the larger 278mm setup on the front.
i dont know what its called but i also need to know if i need to use a different part with this new setup or if the old one is the same heres the pic of it..
EXAMPLE---CALIPERS/05
Calipers/?= use svt= the piston diameter is bigger
Rotors/?= use the 300mm svt
Ball Joints/?=the '05+ use the bigger taper ones
Spindels/?= use the '05 ones, the '06+ use a bigger diameter strut
Brake Lines/?
= stock will work, Stainless steel is best
The '05 spindle uses the earlier strut & uses a bigger tapered ball joint stud, so you'll have to change your LCA's for '05+ arms.
felixthecat is online now
