[?]I can't get my tail light assy off to change a bulb. I got both screws out, but it's still holding near the top. From looking on line here, I find out it's a plastic clip holding. It's really cold here now, I'm afraid I might break the clip off if I force it; which way does this thing have to move to disengage this clip? Does it slide down, towards the bumper, or straight out, away from the car, or what?
It's probably just stuck somewhat and you'll have to pull abit harder. There is a rubber seal on the edge of the taillight housing where it meets up with the back side windows that sometimes sticks. There is only two screws, a phillips (star) one located on the inside trough of the trunk near the weather stripping and a hand bolt (plastic) that you remove from underneath and inside the trunk area.
The wiring is attached to the bottom of the taillight housing with these push on clips (push onto round pegs) so don't pull as super hard on it. You have about a foot to a foot and a half 'play' in the wiring once the taillight housing is actually pulled out.
There are no clips holding the taillights down (no plastic ones) but just the two screws. Make sure you pull the housing back straight and not angled. The 'screw' that the hand bolt attaches to is inserted through the car's structure so that you can put that hand bolt on through the inside of the trunk (you will know what I mean when you see it).
Pull it straight out and try not to push the housing to the outside of the car when you pull it out. I am betting that they rubber seal is sticking. You can probably take a very small (thin) flathead screwdriver and work your way between the side back window and the taillight housing to break clear the rubber seal. Make sure you pry (lack of a better word) between the rubber seal and the window cause the rubber seal is attached to the actual taillight housing, not the window.
It's just being held on by that rubber seal now. It's pretty annoying to get a grip on the taillight, but you just have to grapple with it and tug it out of its place. Trying to grab it on the window end with either your fingers or a flathead as mentioned above would help. And pull straight out, you'll feel the rubber start to give and the light will be free... still attached to its wires of course.
I got it- thanks to both of you. The thing was just stuck, as you said. I felt silly when it snapped loose, couldn't have been easier... If this was any of my last couple cars I would have just yanked the damned thing off and the hell with it, but this one is my baby; gotta be careful!
Yeah, I had a tough time with left and an easier time with the right side. It just WOULD NOT come out! The rubber trim broke a little but whatever. I have another set of tinted tails anyways.
Great, glad ya got it and we could help ya.... [thumb]
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
