Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Putting a cone filter on stock intake
Old 06-13-2012, 09:13 AM   #54
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
What I Drive: 97 Impreza coupe, 04 Mazda6
Points 45,306, Level 100
Points: 45,306, Level: 100 Points: 45,306, Level: 100 Points: 45,306, Level: 100
FF Reputation: 13 TheGlassMaker Great Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by Magus2727 View Post
Zetec has the PCV connect to the back of the intake manifold. The breather valve on the Zetec valve cover goes to the air box so its port is after the stock filter and before the MAF.
There is a "special" yellow foam filter in the air box about 1" square specifically for this.
Most aftermarke air intake systems will pull this off and either provide or require a second breather filter. Ideally you would still want some vacuum on the line like it would see in the stock configuration, but is not needed.
The main reason for this is because emissions usually require any "vapor" from the motor, must go through a "device".... these devices on a focus (and most cars) are the catalytic converters. Routing the "vapor" through the intake is the answer to this problem. but once you get miles on it usually it just mean that its coating your intake with oil because manufactures usually skimp on having a good oil/air separator installed.
Spi is the same way. The pcv is on the drivers side of the valve cover it goes down to just below the throttle body. The breather tube comes from the air box with a 1" filter and goe into the passenger side of the valve cover.
Do one thing every day that scares you. -Eleanor Roosevelt
TheGlassMaker is offline
