Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hughesy's 2nd Gen Duratec Turbo Build
Old 06-12-2012, 05:48 AM   #25
sutyak
sutyak's Avatar
Fan#: 12724
What I Drive: Turbo 04 DSG Mach 1
Points 15,704, Level 80
Points: 15,704, Level: 80 Points: 15,704, Level: 80 Points: 15,704, Level: 80
Level Up 71% Completed
FF Reputation: 62 sutyak Excellent Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by Hughesy27 View Post
well that sucks seeing as mine already came in and I ordered banjos to match them. If I have the right clamps for them will they work? If not, I'm out 35 bucks. I don't see why they wouldn't work. they have different perforated edges on them.
the ones on my turbo are much larger. the 3/8 outlet fits inside them but seeing as my turbo is recommended for 6an, this should be perfect for it.
Quote from bmylez on FJ:
"Bad news, man. That brass tee you posted is for PVC pipes, NOT rubber hose. I made that mistake on my first go-round on the SVT and that ish leaked like a sieve. You need tapered barbs, not the PEX fitting you have pictured. Even though it says it's for 3/4", it will not seal correctly against a 3/4 rubber hose. I had everything tightened down, poured in a gallon of coolant, and then had all of it leak out in about 15 min."
mark
'04 Mach 1. Built. Turbo. 667whp/631wtq
'06 Focus. Built. Turbo. WMI. (sold)
'03 Mach 1 : 12.61 @ 106.59 (sold)
sutyak is offline
