Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Relocating fuel filter to engine bay - drawbacks?
Old 06-09-2012, 01:23 AM   #1
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Would there be any drawbacks in relocating the fuel filter to the engine bay for the SPI/Zetec models? Without spending too much time on other than how, it appears it could easily be done.
Why? - saving time under the car with that ~7/16" screw.
How? Using an old filter, cut off the metal inlet and outlet tubes. Flare the ends just enough to hold rubber fuel injection hose then clamp on enough rubber fuel injection hose to span the gap between existing connections where the filter used to be located under the car.
Mount the filter in its new location just prior to the fuel pressure dampener in the existing rubber fuel injection hose. Determine a method to secure the filter.
Is there a reason as to why the filter is closer to the tank instead of in the engine bay? Fire danger? Surely some cars have mounted a fuel injection filter under the hood.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
