Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 with 175whp
Old 06-06-2012, 09:45 AM   #11
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,831, Level 25
Points: 1,831, Level: 25 Points: 1,831, Level: 25 Points: 1,831, Level: 25
Level Up 31% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by kylesvt720 View Post
That's false. I suggest you avoid practicing law, as you wouldn't fair very well. Also avoid engineering fields, as you would fair poorly on making conclusions based on the facts at hand.
I do very well in my engineering field, thank you. I'll ask you again: What makes your assumption more accurate than FocusBoy58's assumption?
Or will you just ignore the question?
You both had one and only one truth in your calculations--the FWHP from FocusBoy58's recent dyno. Neither of you knew the true parasitic loss, or the actual crank horsepower from his engine. Due to that fact, you were both calculating with the same degree of accuracy.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
