Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 with 175whp
Old 06-06-2012, 09:37 AM   #79
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,806, Level 25
Points: 1,806, Level: 25 Points: 1,806, Level: 25 Points: 1,806, Level: 25
Level Up 6% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by kylesvt720 View Post
Bogus numbers? I calculated the most accurate numbers possible, based on the facts we have. Can you calculate something more accurate?
No, I can't. But FocusBoy58 was calculating numbers as accurate as yours, and you didn't like his numbers! Why bother calculating equally inaccurate numbers when you know the only accurate numbers come from an engine dyno? Because, after all, that was you point all along, right?
You are assuming that Ford's stated hp is what you would get in an actual test on an engine dyno.
FocusBoy58 was assuming a % parasitic loss.
What makes one assumption more accurate than another?
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
