Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Adding Subwoofers to a Titanium
Old 06-05-2012, 10:19 PM   #18
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
Points 2,541, Level 30
Points: 2,541, Level: 30 Points: 2,541, Level: 30 Points: 2,541, Level: 30
Level Up 61% Completed
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
Your best solution would be run the leads going to the sub into a LOC, then into another amp, then to a new sub or better sub in the factory box. At least that way you will have some real power going to the sub, instead of the crap sony amp they use now that is rated at 390 watts total for all 10 speakers, and that rating is more than likely peak power. The RMS is probably around 200, then divide that into 10 speakers and you get like 20 watts per channel.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
