Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Adding Subwoofers to a Titanium
Old 06-05-2012, 03:03 PM   #17
mellonas
Fan#: 98545
What I Drive: 2012 Black Ford Focus Titanium
FF Reputation: 1 mellonas Good Standing Member
Originally Posted by kaptinkurk View Post
Yes, I have added subs to my 2012 focus, however it is an SE and without the sony system. The sony system is going to cause you much more problems than the regular 4-6 speaker configuration because of the built in amp/sub. You could just splice in an LOC and run that to add additional subs to run aside the built in sub, however you will want to be careful how much strain you are putting onto the alternator after doing this.
This is why it is not really recommended to adding aftermarket subs to the sony system, or any system with amps/subs added in by stock. You have to fully know what you are doing and what to order not to cause problems with the stock configuration. The last thing you want to do is add subs to it not knowing what your doing and cause hundreds/thousands of dollars of damage to a no longer warrantied sound system.
I would definitely get a professional to install at this point, because it is becoming more difficult than I imagined. Or I might just forget about subs altogether. By the time I got a custom box to fit well in the trunk and a professional installation and what not, it would prbably costing more than it's worth.
mellonas is offline
