Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replaced Head - Now a couple issues
Old 06-04-2012, 05:33 PM   #10
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
It probably wouldn't hurt to do a compression check on all cylinders before you swap/ disassemble anything. That might tell something. Did you happen to do a compression check on the old original head - maybe compare numbers also.
Plus I'm sure many would be curious what your compression numbers are now too.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
