Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The TICK build thread
Old 06-04-2012, 10:50 AM   #15
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,129, Level 77
Points: 14,129, Level: 77 Points: 14,129, Level: 77 Points: 14,129, Level: 77
Level Up 20% Completed
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
Name that gasket
I got the Fel-Pro lower gasket kit from C-F-M I have already installed the rear main (along with its gasket)
I have also identified in the above image (from right to left) the PCV/oil seperator gasket, oil pick up gasket, front main seal, oil pump gasket.
I have not gotten to the point on using the other 4 gaskets. I am guessing that the large paper gasket is for the water pump. This remains the large black and small brown rubber o-rings and the ridged white plastic o-ring.
Also in regards to the oil pick up. Right now there is a soft green gasket recessed in the top of the tube, this is the gasket I was expecting in the kit... do I remove this gasket and use only the full paper gasket?
Thanks!!
Magus2727 is offline
