Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Question about Titanium Handling Package
Old 06-04-2012, 10:43 AM   #10
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
What I Drive: 2003 2.0L Grabber Green Zx3
Points 26,907, Level 97
Points: 26,907, Level: 97 Points: 26,907, Level: 97 Points: 26,907, Level: 97
Level Up 56% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Originally Posted by cappa View Post
my tpms sensor went off this morning... the ones on the right were at 30 psi and the ones on the left were at 20 psi. I put air in them and put it at 45 psi(max tire is 50 psi) will this be an issue anyone thinks?
Posted via FF Mobile You go by what is the recommended tire inflation, which should be in your manual and on the door frame sticker. I doubt it is 45, sounds way over inflated. Check what its supposed to be and deflate immediatly before you mess up your tires. Your pretty much riding on the center of your tires now and the outsides arent even touching the ground.
DrkKnight614 is offline
