Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replaced Head - Now a couple issues
Old 06-01-2012, 09:26 PM   #2
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Check your timing to be sure the marks didn't move, TDC on compression stroke, after you put the belt on.
Your hydraulic lifters seem firm when you try to push down on each one - not soft or spongy?
It looks like you didn't have your original head reworked but rather got a used reworked head with unknown mileage?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
