Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - FI Duratec fuel requirements
Old 05-31-2012, 09:30 PM   #5
sutyak
sutyak's Avatar
Fan#: 12724
What I Drive: Turbo 04 DSG Mach 1
Points 15,350, Level 79
Points: 15,350, Level: 79 Points: 15,350, Level: 79 Points: 15,350, Level: 79
Level Up 50% Completed
FF Reputation: 62 sutyak Excellent Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by 1turbofocus View Post
You are correct , its the fuel pump not the Injectors
Idealy you want 1psi fuel psi fro each psi of boost with base fuel at 41psi , so 10psi boost you would want 51psi fuel , this is hard to do with the tuning software we have to use and the returnless fuel system , so what happens is as you go up in boost the injectors do x amount of dutycycle as the fuel psi falls off the dutycycle goes up to make up for the loss/lack of fuel psi to maintain A/F this is why it is best to always run larger injectors then needed because you burn up a lot of injector dutycycle just from not having enough fuel psi
With a return system you put a Vac line on the fuel psi regulator so every psi of boost adds 1 psi of fuel psi , makes life easier
Tom
That does sound simpler to tune for. Know where I could find a list of parts necessary to convert to a return system?
mark
'04 Mach 1. Built. Turbo. 667whp/631wtq
'06 Focus. Built. Turbo. WMI. (sold)
'03 Mach 1 : 12.61 @ 106.59 (sold)
sutyak is offline
