Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Block build help.. NEEED INPUT !
Old 05-31-2012, 06:14 PM   #9
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 13,880, Level 76
Points: 13,880, Level: 76 Points: 13,880, Level: 76 Points: 13,880, Level: 76
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
the 300 to 325HP is what I am shooting for also as its at the limit of what return-less fuel system can do. you can do the 300ish HP with a boost a pump and a turbo size that would still make it fun for a DD... However you are also going to need to upgrade the transmission (clutch and will want a limited slip differential). Realize though that a Foci with 300-350Hp is almost 3 times the amount of power out of the same block.
I am right there with you on the money side... have a few hundred every month or so to spend so getting pistons here, rods there, bearings down the road, ect... is still more $$ possible for me than a lump sum.
Many people use the probe pistons or the JE pistons. dont think you will go wrong with either.
Magus2727 is offline
